Results 1 to 8 of 8
Thread: How would you cover this pool?
    Apr 2017
    Seattle, WA
    29
    Newbie here getting ready for my first summer owning a pool, TFP has been incredibly helpful. In another thread I got some great advice on whether to replace my heater (which was DOA) with gas or electric heat pump.
    Seems like keeping it covered will be a key part of keeping the costs down, and I have read a ton on these forums about covers.
    As you can see in the photo my shape and space situation is a bit tricky.
    Any suggestions for how you would cover this pool in a way that is convenient to take on and off?
    The pool is 16x26 not including the half circle caps at each end.
    Thanks!
    Seattle, WA. 17K gal, 16x26' in-ground plaster
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: How would you cover this pool?
    Easy and quick will be the hard part.
    I would get a over big rectangle cover and cut it in half at first then again if the half part is too heavy/bulky for you to handle.
    Kim
    Apr 2017
    Seattle, WA
    29
    Thanks. And silly question but when you remove the cover do you just slide it off and set it off to the slide of the pool?
    Not sure we have room for a roller -- perhaps along the left side of the photo though I am not sure how easy it would be to do a roller on a long edge of pool.
    Jul 2012
    Tallahassee, FL
    33,917
    I really don't know as I do not cover my pool due to my cats. I do not want to take a chance of one of them trying to walk on it.
    The reels do take up some room. My reason for telling you to cut it was so you could just slide it on and off by your self.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    You could buy it long and cut to fit or just skip covering the half circles. Cutting it in half makes it easier to handle for sure. We cut ours and it helps a lot. We do not use a roller. When temporarily removing the cover we fold in half a couple of times halfway out of the pool and then fold it over a few times making about a 4'x4' pile of cover. Then just unfold it back into the pool to recover. At the end of spring and end of fall we lay it out, let it dry and fold in half lengthwise a couple of times, roll it up and put it away. 8 mil and cheap is what we recommend. My 8mil clear is great. Or blue is fine too.
    Apr 2017
    Seattle, WA
    29
    that's really helpful, thank you. seems like some trial-and-error is going to be the way to go to figure out what will actually be convenient enough in practice.
    Aug 2016
    Pittsburgh PA
    345
    Not sure why you couldn't get a cover reel in your situation. When you're using the pool, two people can lift and move the reel over against the fence. As for the shape, buy a rectangle and cut it to fit your pool. If using a reel, you could probably cut the far end semi-circle and just not the one under where the reel will sit.
    The hose reel only needs to sit a few inches off the edge of the pool on either side.
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Sep 2013
    Nashville, TN
    405
    Our pool is 18x36 and we cut the cover in 4ths, we are able to fold each section and hang over the fence or set out of the way
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
