Results 1 to 7 of 7
Thread: Question about damage from copper algaecide
    Sep 2011
    Atlanta Ga
    327
    I have been using the BBB method for several years with good results. I first learned about it on this site. Thanks.
    Recently I hired a guy to vacuum and brush my pool. I did not make it clear to him that was all I wanted him to do and that I wanted to continue doing the chemicals myself. He added some copper based algaecide. We talked and he knows not to add anything more, but the copper based algaecide is alreday in the water.
    What damage will this do and do I need to modify the BBB method in any way going forward? Is it enough of a problem that I need to drain the pool? I really don't want to drain the pool if I don't have to.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    40,848
    Re: Question about damage from copper algaecide
    One dose of copper should not be enough to cause any problems.
    Keep calm and carry on
    Sep 2011
    Atlanta Ga
    327
    Now my chlorine tests don't work, and I know there is plenty of chlorine in the water because I just added it.
    When I do the daily test, adding the R-0060 to the water, the water is clear, showing there is no chlorine, but I know there is.
    When I do the drop test and add the R-0870 powder to the water, it doesn't turn nearly as pink as it used to. It is more of a light purple color. This is the first time I am doing the drop test this year and the
    R-0870 powder is over a year old, so maybe that is the problem.
    Does copper mess up chlorine tests, or could it be some other chemical he added that he didn't tell me about?
    27000 gallons
    Pool built in 1971.
    40,848
    Depends on what all was added to the water. Did you do the CC test? That might show as high.
    Although the yellow OTO test is pretty foolproof.
    Sep 2011
    Atlanta Ga
    327
    I used some newer R-0870 powder and the water tests OK. I guess these chemicals do loose potency over time.
    I added more chlorine and the yellow OTO test works.
    I do think something he added effected chlorine testing because I had to put in twice as much as usual to get the yellow OTO test to work. Or maybe there is something growing in the pool eating up the chlorine, or maybe more sunlight is having a bigger effect than I thought. CYA is 40.
    Any idea about any of this would be appreciated.
    Everything seems OK now though. Thanks for your help
    27000 gallons
    Pool built in 1971.
    40,848
    I know there are chemicals that can appear as a cc but I would have thought that would show up on the Oto test. At least it sounds like everything is working as expected for now.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Some of the real cheap algaecides eat chlorine. Maybe he used more than one type.
