Sooo...I noticed the other night that I had a small leak where we clamped the flex pvc to the water bond male adapter that I had threaded into the bottom of the skimmer.
I wasn’t crazy about that connection because the flex didn’t fit as tight as I would have liked.
Anyway, I fixed it with some parts and pieces I had kickin’ around...
1 1/2” to 40mm adapter
40mm Intex nut on a box adapter
cemented in a 1 1/2” pvc coupler
flex pvc cemented on the other end
no leaks at all now...but I did notice something...
Before I changed the connection, you could see ‘turbulence’ in the clear plastic top of the pump strainer. Now with the leak fixed (could have been sucking air too?) there is no turbulence in the strainer now.
Why?
Is it because it’s not sucking air now?
Why?
