Thread: Opened pool; 2 Jets working, one is not.
    Jun 2016
    Graysonville, MD
    5
    Hi Everyone,
    I opened the pool today and I have an issue with one of my jets.
    The pool is a 13,000 gallon, in-ground, concrete with DE cartridge filter. I have 3 total jets and one is not working.
    Here is what I have done so far:
    Checked all valves
    Worked the skimmer valve back and forth
    Capped the working jets to build pressure
    Used a drain king in both the skimmer and at the pump
    I'm stumped. Any ideas?
    Thanks!
    13,000 Gallon, In-ground, concrete, DE Filter, Mid-Atlantic
    Sep 2013
    Nashville, TN
    405
    Re: Opened pool; 2 Jets working, one is not.
    Are all 3 jets on separate runs? If so, do you have a valve to select only that run?
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Just to avoid any possible confusion I'm assuming you are referring to standard returns in a pool, and not jets as typically used when referencing a spa that blows air + water, correct?
    Is it the furthest return from the pump? have you tried probing up the return?
    All I can think of is that trash has collected at the end of the line, and took the last exit at the end of the road.
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Just to be sure... this return has worked in the past? I'm only asking because if it's below the skimmer, it's an equalizer port and not a return.
    Jun 2016
    Graysonville, MD
    5
    Quote Originally Posted by Sseaman View Post
    There is only one valve that returns to the pool. I have looked everywhere for the possibility of another valve, but there is only the one.
    Yes, the returns, not a jet as in a spa. It is on the opposite side of the pool from the pump, but so is the other working return on that side. I placed the drain king in the return and it blew right off.
    I'm pretty sure, but now that you say it, I wouldn't bet a paycheck on it. It is closest to the skimmer, but not right under it. The company that closed the pool left three eyeballs in the skimmer basket. The return (or equalizer port) in question was capped. Air came out when I remove the cap.
    Quote Originally Posted by foobert View Post
