Thread: impractical slam?
    Apr 2017
    marlton/nj
    23
    impractical slam?
    I am planning on shocking slamming pool this weekend. I have been keeping fc 1.5-2 for a couple weeks dealing with scale. (as per instructions on product purchased).
    latest number are:
    fc 1.5-2
    cc 0.2 (a week ago)
    ph 7.6
    ta 65
    ch 300
    cya 70-80
    its a 31k gallon plaster salt pool. I have never ever had a anything but crystal clear water (except when shocking). last year, before finding this site, I would just add 3 lbs granular shock to pool once every 3 weeks. once that was done my cc was always 0.
    so my question is, to slam this thing as per instructions, I would need at least 16 gallons of bleach minimum. I have a case of shock from last year that I would like to get rid of but not at a risk of raising cya. again, water right now is clear. should I be doing this?
    thoughts?
    thanks
    anthony
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: impractical slam?
    If your water is clear I'm not sure why would would want to SLAM? In NJ, unless you have a SWG, you would be better off draining some water to lower CYA and just start using bleach.
    Also, it might be a good idea to print this out and leave it by your testing area: Pool School - Chlorine / CYA Chart
    As you can see you are far too low right now.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,964
    I am also unsure why you want to slam.
    .that depends on the ingredients
    Apr 2017
    marlton/nj
    23
    Quote Originally Posted by Mr Bruce View Post
    kept it that low on purpose as per instruction on Scale Tec, which actually works I might add.
    ok then, no slam it is. my thought process was to get rid of the cc which im thinking climbed by now from the low fc level I have been maintaining. I haven't tested it since there was nothing I was going to be doing about it at the moment (again, the instructions).
    thanks guys
