Thread: AcuRite wireless thermometer
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    363
    Just bought myself an Acurite pool and spa thermometer from Home Depo for ~US$35. Are they alright? If I tie it on to a bollard in the middle of the pool will it stand up to a bit of bumping arround into the bollard.
    I've had two of the ebay floating thermometers but they only last about a season.
    The Acurite one has high and low daily temp and a history chart which is pretty cool.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Re: AcuRite wireless thermometer
    If you do a quick search on the forum it will turn up a lot of complaints of failures due to water getting in the unit, hopefully you will have better luck:
    https://www.troublefreepool.com/thre...l-Thermometers
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    AUSpool's Avatar
    Sep 2015
    363
    Thanks, looks like they've had some issues. The old photos look a bit different from the one I got. Mine is sealed around the top and looks like it comes apart with a 2" union fitting to put the batteries in. Hope I have better luck with mine but will keep the receipt just in case.
    Steve.
    tcrote5516's Avatar
    Jun 2014
    New Hampshire
    111
    I bought 3 of them never getting more than 1 season out of any of them. Don't ask why I kept buying the same one, thought the third one was the charm....no such luck. Should have known better because my boat; which sole purpose is to float has a bilge pump for a reason because water always finds a way to go where it's not suppose to go.
    - Tom
    Check out my DIY YouTube Channel @ https://www.youtube.com/channel/UCbq..._as=subscriber
    AUSpool's Avatar
    Sep 2015
    363
    Thanks, and I guess even the smallest amount of water and the batteries are not a good combination. It might pay to pull it out and open it up to air and or dry out on a regular basis.
    Steve.
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,111
    I have had several brands of floating wireless thermometers, including that one. The only one I have had that ever lasted more than a season is the Ambient brand. You can find them on Amazon or order direct from the manufacturer. They are sealed better and use a solar cell to augment the batteries so they don't need to be opened as frequently.
    They also have a desiccant pack in them to absorb some of the excess moisture. A good idea regardless of brand. Opening frequently just increases chances of a leak.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
