Results 1 to 7 of 7
Thread: How long to run pool after adding calcium?
    May 2012
    Lexington, SC
    132
    I just added calcium. I searched the forum but couldn't find anything easy on how long to run the pool afterwards. Thank you!
    13,500 gallons
    Sand filter
    IG
    TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    Re: How long to run pool after adding calcium?
    I'd run it all day.. 24 hours even. I like to be sure and with calcium and salt I think a day is a good rule of thumb.
    I just drove thru your town today... you should have hollered, I'd have honked and waved! LOL
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2012
    Lexington, SC
    132
    Thank you! Next time you honk first! Lol!!
    13,500 gallons
    Sand filter
    IG
    TF-100
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    363
    I mix it in a bucket and pour into the skimmer with the pump on. I leave the pump on for about an hour but I guess just long enough the get it through the system and out into the pool would work. Mixing in a bucket is exothermic, the water calcium / chloride mix gets warm.
    The pool chemical page doesn't give a TFP preferred method of adding? Maybe someone could edit that.
    Opps, cancel that, the offical method is:
    Calcium products should be spread across the surface of the deep end of the pool.
    I still prefer mixing in a bucket and tipping slowly down the skimmer, is there anything wrong with that?
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    I wouldn't add it through the skimmer.
    Support the site
    AUSpool's Avatar
    Sep 2015
    363
    Quote Originally Posted by JamesW View Post
    Will a high concentration calcium solution react with anything as it goes through the system? I suspect there is a high potential for calcification within the SWG.
    Would mixing in a bucket and pouring in the deep end or into a return stream the same as acid work?
    Steve.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    It will heat up significantly as soon as it makes contact with water which isn't good for pool equipment or a bucket. We recommend broadcasting it across the deep end of the pool. More here about adding chems to the pool, Pool School - Recommended Pool Chemicals
