Sebastian, where did you read that? I know you CAN put foam up on the walls and such but I have seen meany times where it will fall down for some reason or another and cause lots of problems.
Kim
Kim
Kim
Well yes they did put foam between the liner and the steel wall. I wasn't present when they did it but I can still feel the sponginess of it after 11 years. I still have the original liner and there no problems with the foam backing falling or bunching. Here is a video of Juliano's doing a liner replacement and at round the 2:25 point is where they install the foam. They do use some type of adhesive.
Here what you can expect next, the laying down of the vermiculite.
Vermiculite completed
The liner installed and pool being filled
and the completed pool (prior to fence being installed)
The color is nice now and will get even better as it gets balanced.
Do you have your test kit yet? Do you know which one you are getting? Look in my siggy for the test kit that tests everything.
Kim
I live east of you in MA and have a heatpump as well. A lot of it depends on a few factors such as heatpump BTUs, size of pool, and mainly outside temps. A solar cover will make a great difference as well. I have yet to turn my heatpump on for the season. Outside temps just are not warm enough yet to get water temps up. If you don't have a solar cover to put on at night you will just lose what you put in for the day if you were to turn it on now. You really need a couple of days in the mid 70s and higher to get your water to where you want it. Even though most heatpumps say outside temp needs to be in the 50s or 60s, I have found that 70s and higher is actually best. Next weeks looks like it will be great for using it. I don't bother turning mine on when it rains. A quick shower is one thing, but if the day is a washout like we have been having, then you are just spinning the electric meter. I love my heatpump, and it works amazing when the outside temp is in the 70s. With my solar cover on at night I barley lose any temps, even on colder nights. I was able to swim well into October last fall with the heatpump. This spring has just been too chilly and wet.
I love your water color! Very pretty.
