Thread: Plaster Question 11 months in
    Feb 2016
    Houston, TX
    77
    I wanted to get opinions on some things we've noticed with our plaster nearly one year after our build. We aren't night swimmers and rarely use our pool light, so it wasn't until a few weeks ago when we were in the hot tub one night that we noticed some issues in the finish that aren't easily visible in the daytime .
    We'd been in contact with the builder over the last few months about a black line (trowel burn?!?) at the bottom of our steps. Did the normal builder thing: he had us try a bunch of different stuff (waiting for plaster to finish curing if it was small hairline crack, treating for black algae, rubbing tab on the line) but what we noticed with the light on is beyond that one issue. There are a lot of imperfections, including a very light shoe print. Some bumps, swirls, waves, etc.
    What is an acceptable level of imperfection? We'd noticed some small imperfections, but nothing like what we can see at night. Now that I know it is there, I'm concerned about the quality of the plaster job.
    Thoughts? Advice? Suggestions? The plaster sub is coming out to look, but I fear it will be "that's how it is/normal."
    Water in, we're swimming! IG 18x29 gunite, 3.5-6.5 depth, 14,000 gallons approx, 1 skimmer, Hayward 4030 cartridge filter, Hayward Tristar VSP, 20 ft. raised bond beam with sprayers, 40 sq ft sunshelf with 2 bubblers, 7 ft round attached spa, Hayward 250k heater, quartz plaster, travertine coping, approx 800 sq feet acrylic deck
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,883
    Re: Plaster Question 11 months in
    The only one I would really worry with is the first one. What does it feel like? All of the others can be called "normal".
    Kim
    Sep 2016
    Dallas, Texas
    188
    Quote Originally Posted by kimkats View Post
    Kim
    I agree with Kim. Hand troweled plaster applications all have the imperfections you notice when the pool light is on. It bugged me at first too until I saw post after post of others with the same
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Feb 2016
    Houston, TX
    77
    The first pic of the line doesn't feel terrible. It is a bit rougher, and there are some little gouges, but it isn't algae.
