Sorry about that, I missed the response!
So we finally filled the pool 3 days ago. It's about 1300 gallons (10ft by 30in, although when properly filled it's more like 27ish). A few observations:
Is it normal for a pool this size to have chlorine completely depleted in one day? I put chlorine in according to the pool math calculator on the first day. The second day, it seemed to test 0. That didn't seem right. So I added some again and tested an hour later and FC was 6. I tested today (day 3) and it seems gone again. Is this normal? CYA is 0, so is it normal for that much FC to vanish in 24 hours, even on a cool, overcast day?
It depends on your CYA level, amount of sun, water temperature, and what might be eating the chlorine. Most pools use about 2-4ppm per day of chlorine, some may use a little more, some less. My next response will address why this might be happening.
Speaking of CYA, I can see the black dot even when filling the tube. I assume that's normal for water straight from the hose. There seem to be cheap, common, household solutions to expensive pool chemicals, such as bleach, baking soda, and 20MT Borax. There doesn't seem to be something similar for CYA. Is that right?
Fill water has 0 CYA. There's no reason to buffer or UV protect chlorine that is in the water pipes.
You'll want to go to your local big box store, or even a pool store, and get
solid stabilizer. The liquid stuff will cost you more. You need enough to get your CYA to 50ppm - which is what we need here in AZ to avoid burning off a TON of chlorine per day due to our persistent, hot sun. You add solid stabilizer (or conditioner) to your pool by putting it into a sock, and either hanging that sock in front of a water return (don't let it touch the side of the pool), or by placing the sock (with the end tied shut) in the skimmer and keeping the pump running until it's dissolved. From time to time, massage the sock vigorously with your hands (grind the granules together - you'll see an opaque cloud come out of the sock) to help it dissolve.
I haven't tested calcium, and you guys mentioned that on it's own it's apparently not a big deal for vinyl. Do I need to test it due to having a relation to something else though?
It's only important with regards to your CSI (calcium scaling index). This can be calculated in Poolmath but it is not a big concern for vinyl pools.
pH seemed to be right on the money at 7.5 and it seems to have held.
[*]TA was 190 the first day? Does that seem right? And it seemed to be 170 yesterday. I haven't tested today. I know I only need to check FC and pH everyday, but I'm testing other things too to get the hang of it. But dang, does this seem right?
That's a bit high. It's a "magic" number though, in that there is no exact recommended value. Most of us tend to keep it around 50-100 based on our pool's natural pH rise. Don't go below 50, but this number will adjust itself as you keep your pH in the recommended range (7.2-8.0 - in reality, maintain around 7.6-8.0 to save acid and your sanity). As you add acid to lower your pH, the TA will naturally come down.
There doesn't seem to be a borate test in the kit. Is this important and something that needs monitoring?
If you haven't added borates, and right now there's no reason to do so, you don't need to test for borates. They are something you intentionally add to your pool and are not required at all to follow the TFP method.
For the FC, is that microscopic blue spoon seriously the one to use? I didn't see any others but it just seemed comically small.
Yup! That's exactly the spoon to use.
The pool came with a 300 GPH pump. Do I really need to run it for 4 hours to fully exchange the 1300 gallons? Or will less be ok?
"Full turnover" is a disproved method. Run it for three to four hours anyways to make sure the pool water is well mixed, but you don't need to target a specific number of turnovers. I like to run mine for about 5 hours a day in the summer in the afternoon to make sure the chlorinated water is being mixed up to avoid areas of my pool becoming dechlorinated as the sun burns off the chlorine, and also to get a good amount of filtration to keep the water clear of debris. During monsoon season, if a storm is coming, I flip my filter on to get ahead of all of the blown in debris, leaves, etc.
