I've been reading that you want to go larger for your cell than needed, but our pool is well under the 20K gallons for the Pentair IC20 (approx 11-12K gallons). Should IC20 be sufficient, or should we bump it up to IC40 just b/c it isn't that much more to do so at install?
Thanks!
Keri
Note, equipment isn't set yet, but plans are for Pentair VS pump and a Pentair 60 DE.
Thanks!
Keri
