Results 1 to 7 of 7
Thread: My Signature Changed
    The gremlins must be at work, my signature has completely changed to:
    AG Pool
    12,000 gallons
    Sand dollar filter, 1.5 pentair pump
    Mine is IG 20000 Gal
    Weird!
    Gary R.
    IG Pool 20,000 Gallons Gunite-Hayward 1 HP Super Pump-Doheny Discovery Pool Cleaner
    Pentair Sand Filter-Raypac Pool Heater 266,000 BTU-PoolSkim Pool Skimmer-TF 100 Test Kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,968
    Re: My Signature Changed
    Hold on and I will get our IT dept on it!
    Kim
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Could there be some other issue going on as well? I just replied to a thread I had "quoted" - my cursor kept jumping up about 3 lines, it would not let me continue typing at the end of my sentence. I haven't had any other PC issues, so that seemed very odd. I finally wrote my reply in a text editor and then copied and pasted to the thread. It is working well now as I type this reply, but did not use the quote feature.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    The signature issue was a software upgrade a few years ago where a few lucky people, like chuckles, got their signature switched with someone else. Every now and then another one from back in the day pops up.
    Aug 2008
    Ontario, Canada
    10
    Same problem here. Not my sig and it won't let me edit it.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,549
    Quote Originally Posted by mg_gti View Post
    I've removed the old signature you were seeing. Can you now try to update it here. If you continue to have issues please PM me and I'll set it up for ya.
    Jul 2012
    Tallahassee, FL
    33,968
    I am sending this to our IT dept. Hold on a bit. If you want to send me a PM with what you want in your signature I will have it changed for you.
    Kim TFP MOD
    IT got to it before I did!!! GOOD JOB IT!!!
