Thread: 22 x 52 intex pool with 2800 gph intex sand filter plumbing question
    Apr 2017
    Lake Odessa, MI
    2
    I would like to re plumb my intex pool to get rid of the stupid T conector in the first pic. It seems I can never get the smaller tubes tight enough and everytime I try to vacuum the pool they start sucking air.My question is how to I take care of the two small input holes? The 2 inch return hole is a piece of cake I found PVC adapters that fit. I do plan on putting a through the side skimmer on as well. Any advice is much appreciated.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: 22 x 52 intex pool with 2800 gph intex sand filter plumbing question
    I just wanted to say....Welcome to the forum!
    We have lots of intex modders around here, so they will pick this up and make suggestions I'm sure. Good luck on the project, and enjoy your time on TFP.
    Essential Links:
    Jun 2016
    Pittsburgh, pa
    369
    Our pools are similar.. i changed out my outlets (suction) for hayward connectors.. all you do is attach one of the gaskets, take a sharp knife.. and (gasp) cut, really it wasnt hard though, be sure to use teflon in any case to prevent leaks.. I also added a hayward side skimmer. I also added the return eyeball that came with the hayward into the existing hole (yeah the original hole will be bigger but it doesnt leak and the hayward is much more powerful due to the smaller diameter).
    The details of my various pvc/mods are in my sig (build link). Hopefully this helps clarify somethings for you.
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    Apr 2017
    Lake Odessa, MI
    2
    excellent I will look into those, I'm thinking of getting rid of the Intex sand filter as the pump is a still to weak in my opinion
