Thread: New intelliflo, plumbing questions
    Apr 2017
    flower mound texas
    1
    My pool is 14 years old and I am upgrading my pump to new intelliflo. Looking forward to saving money
    I have some plumbing repairs from the years and decided to replace the above ground plumbing. Was thinking I could use the pentair pump to run the pool cleaner eliminating the booster pump. Saw a thread here saying it could not supply the flow needed for a 280 Polaris. Oh well I still am simplifying the plumbing a little.
    Crude diagram attached shows what the plan is. I am thinking of adding a check valve after the filter. With old plumbing I had some loss of prime and thought the check valve might help.
    Just waiting on my surge suppressor and coupling to arrive to get started. Oh I am replacing a 2.0 HP Jandy Stealth, great pump but overkill and energy hog
    Any advice is appreciated. Thanks. Dan
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,299
    Re: New intelliflo, plumbing questions
    Dan,
    Welcome to TFP.. A Great resource for all new pump owners..
    You will love your new Intelliflo.
    There is no reason to add the check valve after the filter, and I doubt that is the side that would be causing a priming issue.
    You cannot use the Intelliflo to replace the booster pump.
    Do NOT install this pump without using pump unions... Like this... http://www.poolsupplyworld.com/custo...FQ-BaQodxroF8Q
    They have an O-Ring on the threaded side.. In my opinion, it should be illegal to install a $1,000 pump without them..
    Thanks for posting,
