New intelliflo, plumbing questions
dnagy
Apr 16, 2017
1
flower mound texas
My pool is 14 years old and I am upgrading my pump to new intelliflo. Looking forward to saving money;)
I have some plumbing repairs from the years and decided to replace the above ground plumbing. Was thinking I could use the pentair pump to run the pool cleaner eliminating the booster pump. Saw a thread here saying it could not supply the flow needed for a 280 Polaris. Oh well I still am simplifying the plumbing a little.
Crude diagram attached shows what the plan is. I am thinking of adding a check valve after the filter. With old plumbing I had some loss of prime and thought the check valve might help.
Just waiting on my surge suppressor and coupling to arrive to get started. Oh I am replacing a 2.0 HP Jandy Stealth, great pump but overkill and energy hog
Any advice is appreciated. Thanks. Dan
Dan,
Welcome to TFP.. A Great resource for all new pump owners.. :shark:
You will love your new Intelliflo.
There is no reason to add the check valve after the filter, and I doubt that is the side that would be causing a priming issue.
You cannot use the Intelliflo to replace the booster pump.
Do NOT install this pump without using pump unions... Like this... http://www.poolsupplyworld.com/custom-molded-21063-200-000-2PK-Union-Threaded-2-inch-MPT-x-2-inch-Slip-for-IntelliFlo-2-Pack/21063-200-000-2PK.htm?xzm2&ecmpid=aw_pla_search_21063-200-000-2PK&adtype=paid&gclid=CO-3x-idqtMCFQ-BaQodxroF8Q
They have an O-Ring on the threaded side.. In my opinion, it should be illegal to install a $1,000 pump without them.. :cool:
Thanks for posting,
Jim R.
