Thread: Skimmer not skimming
    Apr 2009
    Louisiana
    64
    Have been working along on my pool with the help of this wonderful bunch of folks. Got ready to vacuum & it did for a minute then I have no suction at all. My pump isn't priming at all - any suggestions?
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    Re: Skimmer not skimming
    Are you filling the vacuum hose up with water all the way first, before attaching to the skimmer inlet?
    Dolphin E10 Cleaning Robot.
    Apr 2009
    Louisiana
    64
    Yes, but when the hose is not hooked up & the pump is running, there is no suction at all on the skimmer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Is there water coming out of the returns? What is the pressure on the filter? Do you know what the clean pressure is for the filter? Is there a 3-way valve in front of the pump to choose between skimmers and bottom drain? Is there a valve set to draw water from the spa?
