Results 1 to 12 of 12
Thread: Solar SWG?
    Nov 2015
    Ok ok
    851
    Solar SWG?
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Solar SWG?
    Two things I don't like about it right off the bat.
    Anode adds minerals, probably copper since they have a warning in their manual that copper can cause stains.
    The chlorine output is so "amazing" that they don't tell you what the actual chlorine output is. So, my guess is that it must be amazingly low and they are embarrassed to say what the actual chlorine output is.
    Donldson's Avatar
    NW Ohio
    3,208
    Re: Solar SWG?
    Yep, the copper makes this a hard no right out of the gate.
    Even without that though, even if this produces enough chlorine for a pool on a sunny day what happens on a cloudy day? Now you have to lug chlorine any time it isn't sunny enough to produce the required chlorine, kind of negating the reason for getting an SWG in the first place.
    If it was 1/4th the price and didn't have the copper anode I might consider it to perhaps decrease the amount of chlorine I need to carry, but at that price it is very much not worth it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Oct 2016
    Phoenix
    203
    Re: Solar SWG?
    Quote Originally Posted by Donldson View Post
    ...what happens on a cloudy day?
    But it says...Amazing Chlorine output even when cloudy.
    Aren't you a believer in advertising?
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    Donldson's Avatar
    NW Ohio
    3,208
    Re: Solar SWG?
    Nope, I believe charts:
    Credit Vernier Software Technology
    JoyfulNoise's Avatar
    May 2015
    14,075
    Re: Solar SWG?
    I was thinking the other day that the major SWG manufacturers should make a chlorine generating robot, similar to cleaning robots. Have the robot float around the pool plugged into a controller and make chlorine without having to run the pumps. Then, just pull the unit out of the water when you don't need it. And, if they really wanted to get a big bump in profit, integrate a cheap ORP probe into it to give some feedback on chlorine generation....
    Matt
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Solar SWG?
    Now this would be interesting!
    Quote Originally Posted by pooldv View Post
    Well... that technically is amazing!
    Isolated Spa - 345 Gallons
    May 2015
    14,075
    Re: Solar SWG?
    Quote Originally Posted by JVTrain View Post
    I suppose product liability would be an issue since some numbskull would likely go swimming with the thing and then have their corneas burned off because they thought it would be a good idea to try to see if they could "detect" the chlorine coming out of the tube. Or, very likely, they try to inhale the hydrogen gas because their buddy told them it would be just like inhaling helium and they'd get the squeaky Mickey Mouse voice....
    Matt
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Re: Solar SWG?
    Ha Ha, they state:
    "Works in both saltwater and freshwater pools"
    When I think of 'fresh water', I think absolutely no salt.........
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Oct 2007
    Parkland, FL
    753
    Re: Solar SWG?
    Umm they made it. It was called the cobia and I beta tested it for a year. It was like 1700 to purchase. Salt cell wasn't very big.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Nov 2015
    Ok ok
    851
    Re: Solar SWG?
    Well I am perfectly happy with my NON scaling Hayward SWG! LOL
    DFW, TX
    24,974
    Re: Solar SWG?
    Yeah, right that was a nice upgrade from the first one!
