My pump was working fine the other day. Tosay I tried to flush my skimmer pipe by using a drain cleaning bladder. Unfortunately the rubber burst. When I turn my pump back on it seems like the skimmer was clogged and the pump has no pressure and won't prime when the valve is on skimmer only.
Did I use the wrong size for the drain cleaning bladder ( used the 1.5 to 3 inches) that's why the rubber burst and this could be the reason why my pipe is clogged. What can I do to resolve the problem and make my skimmer line running again.
