Results 1 to 19 of 19
Thread: 286 lbs?
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    286 lbs?
    I am trying to get a ballpark idea of how much salt I will need when I setup my swg next week and if I put in 0 as my starting point and 3000 as where I want to end up in math it says to add 286 pounds of salt...doors that sound right? I know it's not exact at this point until I get all of my numbers dialed in but I want to make sure I have enough on hand because I live an hour and a half from anywhere I can get salt and it's much easier to return unused than to come up short
    Thanks in advance
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: 286 lbs?
    Yep, sounds good. It's ok to keep some extra salt, you'll need to add more periodically from splash out, overflow from rain and carry out in wet suits. I had to add 120 lbs this spring. If the water has been in your pool for a few years then there is likely a good amount of salt in it already, hundreds of ppm. Bleach, muriatic acid, people and tap water all add salt to pools.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    Re: 286 lbs?
    Good to hear you getting into pool mode for 2017! With your fresh fill last year, you might have 500 ppm but that is strictly a guess, guess, guess. Or if you drained and refilled, then it will be whatever is in your fill water, probably very low. Salt test strips are one of the few test strips that are sufficiently reliable. You can get them, or the slightly more accurate Taylor K-1766 salt test kit from TF Test Kits.
    Congrats on the SWG!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    DFW, TX
    24,974
    Re: 286 lbs?
    Yes, I use the aquachem salt test strips from TFTestkits.net. When adding salt add a bit less than the low target, brush it and let it circulate for 24 hours or more. It takes some time for the salt to fully dissolve and mix in.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    awesome! I thought maybe I input something wrong or wasn't understanding I am just learning all I can about my different care options while this pool still stands. if and when I upgrade or replace this one, I want to be ahead and know what my best options are all around and set up the way I want it from the get-go! I like the idea of the swg so that I can get away from handling bleach daily as that is terrible for my lungs with my COPD and kind of a hassle to try and store enough for the summer while it is on sale...I should be getting my new set up in the next day or so, and hope to have it all up and running before too long, but we have several days of rain heading our way, so I may have to just be happy with reading and studying for a bit longer...I will keep my fc up so that the water doesn't start growing anything in the meantime. it was at 60 degrees last week, but 2 days of 80+ degrees brought it up to around 67 degrees or so...but it dropped again overnight and since our last few days have been cool, it should stay down for the moment.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    I am shopping around looking for the best price for salt and I'm wondering if these are equivalent in quality or if I need to go with the higher priced actual pool saltScreenshot_2017-03-22-12-31-38-1.jpg
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Re: 286 lbs?
    Just make sure there are no additives listed. Sometimes they include anti-caking ingredients that can effect your chemistry.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Re: 286 lbs?
    According to the MSDS the Solar Naturals is 100% salt so that would do just fine.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    awesome! I just called my local ace and found that they have it at 4.99 a bag, 4.49 if you buy 2 - nothing like half price to stick it to the pool stores! whoop!
    DFW, TX
    24,974
    Re: 286 lbs?
    Yes, anything that is listed as 99% salt or better is fine to use.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    And why do they sell sand in a 50 pound bag but the sand filter I just bought requires 55 pounds of sand? That's just silly
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    Quote Originally Posted by pooldv View Post
    I checked the specs on this a little closer and it does say that it is extra course... wondering how that's going to dissolve for me? I am okay with it taking a little longer to dissolve as long as it's going to do so because my pool will not be warm enough to swim in for a while yet so I'm in no huge hurry
    DFW, TX
    24,974
    Re: 286 lbs?
    That will be fine. It usually takes 24 hours to fully dissolve and mix in. So, it might take an extra day or so. Brushing will help.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    Quote Originally Posted by needsajet View Post
    do I need to get a whole different test kit that is for salt pools or just add salt test strips to the tf100? and this may sound like a dumb question...is bromine and salt the same thing when it comes to pools?
    I want to make sure I am squared away as opening time starts getting closer and closer and avoid any green swamps as I get things in order
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: 286 lbs?
    You just add the salt test to your TF-100.
    Bromine is an alternative sanitizer of water, and most pool people steer clear. Salt is .... salt converted by your SWG to chlorine (simplified version).
    You should add SWG to your signature, it can make a difference when asking questions in the future.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    I will definitely update my signature as soon as I make a change to my setup. all of my stuff came in yesterday and I need to get salt and salt test strips and hope to have things all up and situated by the end of the weekend. just trying to get a bit of info in advance so that I will look super smart to my hubby as I go along
    thanks for the info as always!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: 286 lbs?
    You can practice on your fill water too. It's handy to know the TA and CH.
    Jul 2016
    fall river ks
    502
    Re: 286 lbs?
    oh yeah, I am a bit ocd about doing my readings daily once the water gets warm enough to be an issue if ignored. I learned so much last year and am now upping my game a little bit since I understand things better now...but swg and sand are both new for me, so just getting my base of knowledge a bit more level with all my other info so that I can TFP the heck outta my oasis!
    needsajet's Avatar
    Jan 2016
    4,493
    Re: 286 lbs?
    Sounds like you're well set for 2017
    +1 to everything above, and just to be sure, steer clear of bromine in all it's forms, including algaecides. That's one of a few things that can cause serious pool tending headaches.
