Thread: Tile buildup
    Mar 2017
    El Paso texas
    13
    Tile buildup
    I've had a in ground pool for 6 years now. Did the maintenance myself and so far so good with the exception of scale build up on the tile in spa and pool and some staining. Water is hard in west Texas and I'm looking to blast it with baking soda as a quick fix.
    I'm looking for a way to keep the tile clean longer. Someone recommended a device to clamp to one of the pipes and it's supposed to cut down on the scale but skeptical of whether it really works.
    The other issue is some stains in some areas and was thinking of an acid wash to clean up the stains. Have had some algae but I can clean that up so I don't think that's what is causing the stains. Looking for someone to point me in the right direction on these issues. Thanks for looking.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: Tile buildup
    Hi! I am glad you found TFP and your pool will be glad after we get done with it!
    A picture will be the most helpful thing you can share with us so we can see what you are dealing with.
    I would also like to ask how you have been testing your water.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Tile buildup
    Welcome to TFP!
    It is fairly easy to avoid scale by managing pH and TA in conjunction with your CH level. A good test kit is the first step. I use the TF-100 from TFTestkits.net.
    In PoolMath, link at top of each page, after you enter all of your test results it will calculate your CSI. Tweak PH and TA to keep the CSI between -0.6 and +0.6. If you keep it on the negative side it will help to dissolve the scale that is already there. More here, Pool School - Calcium Scaling
    Mar 2017
    El Paso texas
    13
    Re: Tile buildup
    Thanks for the replies. I've been testing with the Pentair kit that the builder supplied, I suppose a new kit maybe a good idea.
    Ill read the link that was provided and try to figure out the size of the pool, it got a weird shape to it.
