Results 1 to 8 of 8
Thread: Intelliflo 2 vst RS-485 cable
    Mar 2017
    Phoenix AZ
    4
    Hello everybody, So I just had an intelliflo 2 vst installed yesterday. It works and runs great but my problem is, I have a Jandy aquapure EI salt chlorinator that is connected to an intermatic timer that would turn on my old Hayward pump and the Jandy at the desired times needed. Now that I have This new pump with a built in timer How do I get it to talk to the Jandy power box when the pump turns on now that the intermatic timer is pretty much out of the equation? I cant leave the Jandy powered on at all times with a no flow condition due to the gasses the cell creates possibly causing an explosion. I'm new to this RS-485 cable gizmo, can I connect that to the Jandy box and when the intelliflo turns on it will send power to the Jandy? I'm not really interested in going with the whole PDA stuff unless that's the absolute last resort. Any help or knowledge with this would be greatly appreciated! Thanks in advance!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,257
    Re: Intelliflo 2 vst RS-485 cable
    Snap,
    Welcome to TFP... A Great resource for all your pool questions...
    Some of the newer Jandy units will "talk" with the IntelliFlo, but not all of them.
    I suggest that you contact Jandy and ask them.
    Your problem is exactly why we always recommend using the same brand of pump and automation.
    Most people here, who have this exact issue, actually run their SWCG off an manual time clock so that it mirrors the pump's timing.
    I do know for sure that some Jandy systems control the Intelliflo so a call to Jandy would be your best option.
    Thanks for posting,
    Mar 2017
    Phoenix AZ
    4
    I will call Jandy. This pump was upgraded by my solar panel install company. More of a free perk for choosing to do business with them. So I take it nobody here knows if I can connect the RS-485 cable to the Jandy control box. Thanks for your response.
    Apr 2015
    tucson, arizona
    1,311
    What Jandy control system do you have? Maybe a picture if you can't find model no.
    Mar 2017
    Phoenix AZ
    4
    Its the Jandy Aquapure EI. I read the manuals for the Jandy and the Intelliflo 2 vst twice and found nothing explaining what I'm looking for.
    Apr 2015
    tucson, arizona
    1,311
    That's a standalone salt system, you would need to install a aqualink control system to run everything
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,109
    Easiest answer is to use a timer to turn the SWG on and off. I just kept my old timer that was running both the pump and SWG. Moved the pump from the switched to the unswithched side and kept the SWG on the switched side. Just be sure it's set for a time period that the pump is set to run.
    If you have a solar system you can use the comm cable the operate the pump from a solar controller. I don't know what the solar company installed, but I have an inexpensive SolarTouch controller that ramps up my Pentair VS pump and turns on the valves to the panels when heat is called for. The kit included the solar valve, actuator, both heat sensors (water and panel) and the controller for $225.
    Simple timer for my SWG and the solar system just takes care of itself. Took a little programming to set up times and pump speeds for each task but once set, it all works just fine.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
    Mar 2017
    Phoenix AZ
    4
    Thanks for your help everyone. I have a solar system for my house not the pool directly. Everything I've come across points toward the aqua link. The idea of having a separate timer for the salt system is good and all. But the problem is the intermatic timer has the potential of eventually gradually getting out of time. Having an extended no flow issue will cause some problems with the salt cell. Thanks again.����
