Thread: Wanting to start Ascorbic Acid treatment... CYA Reading 0
    IronKneebone's Avatar
    Apr 2013
    Apple Valley, CA.
    15
    Hi Folks, Getting a jump on the new swim season and having a bit of Iron discoloring on my steps. The discoloring is just on one end of the steps, where the wind seems to blow everything in the one corner of the pool. The 2 White/Clean spots are where I've dropped 2 Vitamin C tablets
    The other end of the steps is nice and clean
    and The rest of the pool has clean plaster
    So I bought
    3 lbs of Ascorbic Acid
    New DE Filter set
    5 Quarts of Jacks Magic Blue Stuff
    I let the Chlorine lower and lowered the PH. Then this morning I decided to let the local Pool Store check my chemicals. The reason I did this is because I haven't checked the CYA for about 5 months (Ran out of Reagent 0013 and they have been out as well). They came back with similar readings as me except they told me the CYA was 0
    I bought a bottle of 0013 from them and sure enough, test reads 0 CYA
    I have kept the CYA at between 30-40 forever and now it's at 0
    I haven't been using anymore 12% bleach than usual ...weird
    My Plan (From the forum and Jacks Magic)
    Tomorrow when FC is at 1 or below
    Replace filters and add new DE
    While pump is running sprinkle Ascorbic Acid in trouble areas until stain lifts (I have 3 lbs)
    After stain lifts add 2 quarts of Jacks Blue Stuff (Sequestering Agent)
    Slowly raise FC
    PH on my pool rises naturly, so I will let nature raise PH
    Finally for preventive maintenance, add 8ounces of Jacks Blue Stuff every week for the rest of my life
    So my questions;
    Is it a problem having CYA at 0 if I'm not using the pool, it has good chemical reading and no algae?
    Can I revisit the CYA issue later, before swimming season starts?
    Where the heck did my CYA go?
    Does my game plan have any flaws?
    My readings;
    FC 2
    PH 7.0
    TA 80
    CH 400
    CYA 0
    Water Temp 58 degrees (tested CYA multiple times with water warmed to room temp)
    Thanks!!!
    15ft x 30ft IG Plaster 22,00gal - 7ft rnd Spa - Hayward 6020 DE Filter - Hayward 1.5 Tristar Pump - Kreepy Krauly Classic - Pentair S20 Skimmer
    JoyfulNoise's Avatar
    May 2015
    14,091
    Re: Wanting to start Ascorbic Acid treatment... CYA Reading 0
    I would get your CYA up to a measurable level before doing anything else. If truly zero, then even 1ppm FC is way more harsh than we recommend.
    Also, you should use Polyquat-60 as insurance while the FC is zero to ensure algae can't get started. Just because the water is cold does not mean that algae is dead.
    Matt
    Apr 2013
    Apple Valley, CA.
    15
    Got it. Just bought 4lbs and have it in a sock in the skimmer. Hoping that the Zero reading is actually 15-20 and I'm just getting a super low reading.
    I didn't know that bleach was harsh on anything with a low CYA reading. I just thought that the CYA helped it last longer and protect the Bleach from the sun.... good to know
    May 2015
    14,091
    Read through some of the advanced chemistry topics. CYA protects against UV loss AND it is a chlorine buffer, meaning it bonds with the chlorine and holds it in reserve so that it only forms a small amount of hupochlorous acid which is the primary oxidizing and disinfecting form of chlorine. With no CYA, all of the chlorine turns into HOCl/OCl- which is what makes the water harsh. You need CYA to moderate the amount of HOCl/OCl- created.
    Matt
    Apr 2013
    Apple Valley, CA.
    15
    Will do, thanks Matt
