Hey all,
Once I revived my frog swamp using the TFP method, I decided to swim instead of looking forward on closing info. 30,000k+ in-ground with two skimmers, main drain, and a Jandy 99 caretaker. I believe the caretaker is the only form of return I have as the walls are clear to the floor. I was able to blow out and gizmo the skimmers but once I closed the skimmer valve, in an effort to lock the main, the blast of air bubbles came from one of the caretaker heads instead of the main. I locked the valve anyway; I have no idea how this plumbing is ran because the previous owner is deceased and the company closed years ago. Assuming my skimmers and main are ok, how do get the water out of the Jandy's 5 valves? I removed the dome and pushed a high powered shop-vac in one of the lines to see if I could get the level to drop or some air out of one of the heads... nothing. I considered rigging a connector for my compressor but though I should ask before I damage something. Any advice? I can't find anything on this site on this subject. Keep in mind, I'm in Williamsburg, VA and while it gets pretty cold, it rarely stays below freezing for more than a day or two.
Mike
Mike
