I previously just rinsed my finger nest off and would store until next year. After about 10 years use, I noticed the inside side of fingers were darker than outside. This is first year I soaked finger nest in Dawn overnight. When rinsing of, I saw some brightening of outside, but inside of fingers were pretty much the same dark color. I will try soaking in Muratic Acid. I have an air breather with acid filters. I plan on pour acid back into bottles and use in pool to lower ph. Please let me know if you think I am off base.
Now, I bought a new finger nest that was advertised as a replacement nest for Hayward EC40. The only difference I have observed between the two is the finger length (installed). The old ones are 13 inches from white plate to tip versus the new finger nest which is 12 inches from the white plate to tip.
My inclination is that it probably doesn’t make that much difference. I am figuring on adding 3 and 3/4 DE instead of 4 pounds.
My question is do you think this is okay from an operational stand point? Any and all advice is welcome. Thank you!!
