Thanks for taking time out of your schedule to help me trouble shoot my heater, it's much appreciated [emoji1491]
no problem!
I would let TA drop as low as 60. Maybe not actively try to get there now, all though that would be fine. pH life will be better with TA at 60.
For pH, lower it to 7.2 and leave it alone until you get back. For FC, raise FC up to shock level for your CYA, [FC/CYA][/FC/CYA]. Have them add 2-3 ppm of bleach every day or 5-6 every other day. Whatever your normal usage is. And don't have them test at all. I'm all for easy, thank me later.
Here is what you want when you move to salt, Pool School - Water Balance for SWGs
I can't answer your question, but the pucks will add some acid (I'm not sure how much) and CYA.
oh ok i never knew that! thanks!
Did they acid wash the quartz the day after they plastered the pool? Assuming yes, the pool will be fine to raise FC up to shock level after 3 weeks.
That is an amazing amount of pH rise. All the more reason to lower TA. Lower your pH to 7.2, or even 7.0 a few timees, when pH gets to 7.8 as often as you can to get TA down. Lowering TA to 60ish will significantly slow pH rise. Let's see how that does between now and early next week.
Yes, pucks will add acid and lower the pH and TA.
Pool Math to the rescue! Look down towards the bottom for this:
Effects of adding chemicals
Adding [?oz] of [use the drop down to find what you are adding] will [this box will tell you what this or that will do to the levels!]
Note: pH calculations are not exact. These numbers are only suggestive of the relative magnitude of the pH change you can expect. Small changes, +-0.4, with pH between 7.2-7.8, TA around 80-120, and Borate near zero will be approximately correct. The further you go from those ranges the less these pH changes will correspond to reality.
This one of the neatest things to play with to me. Shows how you can tweak your numbers with this and that.
Does this help?
Kim
CSI being a little low for a short while is not a problem. And really it isn't a problem until it is -0.6. I would lower it to 7.2 and see how long it takes to rise back to 7.8 just so you'll know. Then we can make a plan for vaca.
