I have an old transformer in metal mounted electrical pool box (GFCI inline).
Has 120V AC input and its outputting 11.3V AC per my multimeter. It's used to power LED Pool light (s) - which flicker on / off - which I assume is the tranformer. If I use a 12V power supply temporarily with enough wattage, the light lights without issue.
I have two lights right now - first I just bought rated at 30W. The spa light is a hayward universal colorlogic - I think it's rated at ~70w.
So, the question - if I replace transformer with a 'typical' pool light transformer - usually rated at 300W and range from $75 - $150. These transformers make sense when the lights were incandescent. With LED the wattage requirement is so much less. There are waterproof transformers that seem a lot less (for example 60W for $30)
What am I asking? Are these typical transformers required with LED lights and GFCI circuit? I don't want to skimp obviously, but I also don't want to pay $100 just because that's what we've always done
Interested in your feedback!
I'm probably overthinking this purchase as it's probably once every 5 year purchase.
