I'm toying with options to run the valve actuator thru the relay.
Pentair IntelliTouch i5, i7 and even the i9, only support 3 valves on board. 1 of them is reserved for pump operation. Since I'm using IntelliFlow pump, that output is not used.
With the expansion module, I got to use 3 more valves.
I need to add another valve and Pentair T/S tells me to purchase another cabinet called (Pentair 521225 IntelliTouch i5x Expansion Kit), which is not going to happen due to cost.
I do have all those relays (Aux1-8) that are not being used.
Question is, does anyone know of a kit to convert relay wiring to valve actuator, or wiring splice kit to run the valve actuator thru a relay?
I can figure this out, but didn't want to reinvent the wheel if existing solution --outside of the x5-- is available.
