BuckeyeChris' point is that the algae is growing on the surface of the pool (walls and floor) so draining and refilling will still leave the algae in the pool. And you will still have to kill the algae after the pool is refilled.
The way to kill algae in a pool is to follow the SLAM process consistently and completely. It works in hundreds of pools every year.
Test FC several times per day and dose it back to shock level for your CYA, [FC/CYA][/FC/CYA]
Brush as often as you can, once or twice a day is preferred
Here is the process to review and make sure you are following it. SLAM Process
