We generally do not recomend changing sand unless you have used a chemical that has gummed up the sand or calcium scale has turned it to concrete. The sand does not wear out. Pool $tores recomend changing it because they sell sand. Just clean it.
I agree with Tim, but if you must remove the sand best way is to drain all the water out and let the sand dry completely then vacuum out with a shop vac.
No fun! But if it has been a few years since you've changed sand you COULD change it since it's already out. Although fine particles in the sand could get into the pool during the first couple cycles. Plus they say dirty sand filters better than new sand. Good luck hope it's nothing major.
I don't think so. I think it's meant to be more for winterization where you leave it off the whole winter. It will probably take a while to drain that way. If you think it's that dirty maybe backwash it first
If there's no plumbing connected to the filter, then yes you're fine just a waiting game unless you want to try to suck out the wet sand. Just make sure when you disconnected the plumbing that either valves are closed or sealed well so the pool water won't leak out that way.
