- Jun 22, 2014
- 48,000
- Fiberglass
- CircuPool RJ-45 Plus
Best thing to do when you need to know exactly how much of something to add..... go to the Poolmath calculator (link below in my sig). We all use it. Just enter your pool size (gallons) at the top, then enter each column for the "NOW" and "TARGET" or GOAL. Once you do that, the calculator tells you how much of a product to add. When it comes to bleach (FC) though, make sure you manually enter the "weight" (percentage) of bleach you are using. That calculator is invaluable to us at TFP.
Once you add stabilizer, simply consider it at your programmed target. You can check CYA about 2-3 days later. For acid, test (validate) in about 20-30 minutes with pump running and it should be fine. You can have the stabilizer socking in a sock and add acid at the same time.
