Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: 3" chlorine tabs without CYA
    tacoma5050
    Guest
    Why doesn't anyone manufacture 3" chlorine tabs without CYA in them? Is it not possible?
    Or if someone does, where can I buy it?
    Re: 3" chlorine tabs without CYA
    Yes, and no, but really no. There isn't anything that dissolves slowly and doesn't contain CYA. You can get tablets made out of cal-hypo, but they dissolve way to quickly to be used in the same way trichlor tablets are used and contain calcium.
    Apr 2009
    Sarasota Florida
    143
    I was actually thinking about this the other day also. You would think that someone could figure out a way.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Disinfecting chorine is unstable and there are very few ways to stabilize it enough to transport it and still have it work in the pool. There are really only six forms available: bleach, trichlor, dichlor, cal-hypo, lithium-hypo, and chlorine gas. Each has advantages and disadvantages, there is no perfect combination.
    The best approach I have seen is a SWG, which creates the chlorine on site, so no transportation is required.
    Guest
    There are only a few forms of solid chlorine and only one is very slow dissolving, making it useful in erosion feeders. This is trichlor, which is a chemical made from chlorine and cyanuric acid (a chlorinated isocyanurate). The problem with this slow dissolving form of chlorine is that it will cause CYA levels to rise since once the chlorine is used up the CYA remains. The next slowest dissolving form of chlorine is calcium hypochlorite (cal hypo) which does not contain CYA but will cause calcium levels to rise over time. It dissolves very fast in comparison to trichlor so it does not work very well in erosion feeders and cannot be used in a pressurized feeder without danger of explosion so it's usually used in a plastic coated capule or tablet that is placed in the skimmer but these only last a few days at best and leave a lot of residue behind.
    All the other solid forms of chlorine (lithium hypochlorite which will not raise CYA but is very expensive to use and dichlor which will raise CYA faster than trichlor does) are very fast dissolving so they are not useful for erosion feeders.
    The two forms of chlorine tht have the LEAST side effects on water chemistry are lithium hypochlorite, a fast dissolving granular that is EXTREMELY expensive to use, and sodium hypochlorite (bleach or liquid chlorine) which is not as convenient as the dry forms of chlorine but is very economical to use.
    I hope this explains it.
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by waterbear
    Ya i follow all that, and actually understand. But you would think someone would figure out a way to get us the best of both worlds. Slow dissolving tablets that do not jack up your pool chemistry . I can wish..
    Guest
    Quote Originally Posted by mdhwoods
    That would mean developing and testing an entirely new chemical that does not exist and then getting it approved by the EPA.
    Good discussion..
    I assume the CYA rise in using pucks takes a long time? I ask because I added several pounds of CYA last year when our liner was changed (new water obviously). I keep two BioGuard smart sticks in ea skimmer at all times. My CYA is still only 30.
    2003 Marquis Euphoria - 400gal
    Guest
    Quote Originally Posted by jjdurrant
    Good discussion..
    Depends on several factors. You have a sand filter so each time you backwash you are diluting the water. If you had a cartridge filter the CYA would rise faster since you would not be backwashing.
    Bottom line is this. For every 10 ppm FC added by trichlor then you have also added 6 ppm CYA. The chlorine gets consumed but the CYA stays behind so, sooner or later, you WILL have an overstabilized pool! (FC is normally consumed at a rate of 1-2 ppm per day in must pools but it can be as high as 3-4 ppm during the heat of summer and a lot of usage so it's entirely possible for a pool to go from no CYA to too much CYA in one short swim season!)
    Apr 2009
    Sarasota Florida
    143
    lol but we can go to the moon...
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    That's it: SPACE TABS!
    Guest
    Quote Originally Posted by spishex
    I can see the slogan now:
    "Space Tabs--The Final Frontier!"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Mmmm... affordable. Maybe Platinum Hypochlorite?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by Ohm_Boy
    I hear platinum hypochlorite combined with diamonds in your sand filter will solve any pool problem.
    Guest
    but only in the presence of dilthium crystals
    Good discussion..
    Thanks. I plan to stick with the smart sticks for at least another year.. keeping a close eye on CYA of course.
    Mar 2014
    Arroyo Grande/California
    32
    Quote Originally Posted by jjdurrant View Post
    I just read this older thread today because I was wondering why CYA had to be added in a convenient tablet. So, thank you all, especially mdhwoods for the great replies.
    After tiling my black tile in ground spa, I stopped using tables, added a controlled amount of CYA, and I add about a cup of bleach each day, which seems to absorb the sun more compared to when it was a plaster spa. Who knew (?).
    None of the other sanitizing methods mentioned are appropriate for my needs and I would also love the miracle, slow dissolving, not CYA tablet. I would also like beaming technology, as I hate driving.
    May 2014
    Clarksburg, WV
    331
    Just to add to this. Even though its 6 years old...lol
    This is why in late August you usually see the green pools in the neighborhood. It happens every year. June/July everybody's pool is sparkling. Late July/Early Aug, you start to see the water become cloudy, but still decently clear. Late August, the pool stores are packed with ppl complaining about green water. I always knew there had to a reason for this, but until I found this site, I never knew what that reason was. Now it's pretty clear......(no pun intended). Ok, maybe a little....HAHA
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Aug 2013
    Tucson AZ
    19
    Quote Originally Posted by kris77 View Post
    Funny! Just today I asked the local pool dealer about why they didn't carry 3" tablets without CYA. He said "without chlorine?" I said "No, without Cyanuric Acid." He said he thought they could special order them for me.
    Uh hu...
    So yeah, even 6 years later, we all have the same questions.
    14,000 gallons in ground pebbletec built in 2007 with a waterfall feature.
  20. Back To Top    #20
    stevenmverrill's Avatar
    Nov 2015
    Frederick md
    30
    Idea:
    What is the strongest liquid chlorine you can get? (12.5 best I got) if you could find some 30+ you poor in to a 1L bottle pick it 1-10 (or what ever works) times with a needle and then drop it in the chlorinator.
    Bam! Matenence free for 3 days. I need to do this. Otw to see what will fit in my chlorinator
    Better yet I could rig a detergent feeder from an old pressure washer in to the plumbing.
    18x36 rectangle built early 90's, 9ft well, "black onyx" vinyl liner, 1 1/2" plumbing, 2 returns, 1 skim, 1 drain/return, plumbed chloranter, 48sf de filter, multi port valve, and 1.5hp jandy pump.
