Hello the community
I understood the relation CYA and Chlorine, moreover, I have few questions:
If my CYA is low 5, could I use Trichlor tabs until my CYA has a decent amount (around 40)
Most of the time, I used liquid chlorine but with low CYA, I understand Cl disappears quickly.
Also I am feeling dumb to add conditionner, considering most of the people have to empty (or half) their pool to reduce it, in addition I am using and have tabs when I am travel and when I can't take care the pool daily (don't have conditionner). I have a cover which protect the water from UVs.
Another question, if my CYA is around 50 (in the good range), should I stop to use tabs? And only liquid Cl?
The liquid Cl is protected in this case?
Somebody notice using liquid Cl raise pH? (I used a lot of muriatic)
Unfortunately tabs without CYA doesn't exist...
Thank you
3" chlorine tabs without CYA
Why doesn't anyone manufacture 3" chlorine tabs without CYA in them? Is it not possible? Or if someone does, where can I buy it?
www.troublefreepool.com
Thank you
