110v vs 220v for pool pump.
JamesW
16,791
Will a 220v 1HP use the same watts per hour as a 110v 1HP?
Note that you don't say watts per hour.
Watts is energy used per unit of time.
Watts ÷ 1,000 is kilowatts.
The power company charges for total energy used.
Total energy used is kilowatts x hours. So, the power company bills for total kilowatthours.
A pump that uses 1,000 watts uses 1 kilowatt. Every hour that it runs adds another kilowatthour.
1 watt is 1 joule per second.
Energy can be measured in multiple different units. Such as, joules, calories, btu etc.
Power is the amount of energy used per unit of time.
JamesW
16,791
They both use the same watts.
My point was that, when talking about power, you just say watts, not watts per hour.
AndyTN
149
Memphis
Well, I think this whole string of responses confused us newbies even more than when the question was originally posted. My pump is already wired for 220V and I'm not an electrician so I'm not going to touch a thing...
Pool_Medic
In The Industry
Apr 1, 2018
1,197
Bangor Maine
I’m gathering you must of been or are a teacher or professor. My point was about costs, not about joules, watts or whatever. My head hurts, I’m going to lay down now lol
CJadamec
2,390
Quaker Hill, CT
The simple point is that changing the voltage of the pump does not change the energy use of the pump.
The only difference between a 220v motor and a 110v motor is how the wires connected to it are setup.
There is zero reason a pump motor will be any more or less reliable based solely on the voltage its running at.
Not a teacher just an engineer with a couple decades of experience operating and maintaining all forms of power generation equipment.
