I am a new pool owner with only one summer under my belt. The previous owner left me with a mess that I am trying to clean up. I replumbed everything last year (2" with proper fittings unions etc) added a SWG but kept the original pump which I now want to replace. I think it is a Hayward Superpump with a 3/4 Century motor (but maybe used to have 1hp motor.) I am looing for a VS primarily for electricity savings (MA $.33/kwh) but also additional flow. I think the 3/4 hp was right on the edge of being able to run my setup. I looked the pump over thoroughly and the only model number/specs I could find was "SP 1600 AA"
28000 gallon 2 skimmers(1 1/2"), 3 jets (2"), 1 main drain (2")
Hayward Superpump with 3/4 hp 220V Century motor
RJ60 SWG
60cf DE filter
Might add a heater this year
No automation
1) Does anyone have experience with the MA massave VS pool pump rebate? I am struggling to find details. If I can get the rebate I would consider a Hayward VS Super pump 1.65 hp but am concerned I would not be getting the highest possible energy savings, everything I read says get the highest HP VSP possible and run it at low rpm.
2) I am leary of the Calimar Wasterway Black and decker options but also don't want to spend top dollar on Tristar or Whisperflo. I am considering Nidec Neptune on a Hayward Superpump Housing but am confused by the different impellers and diffusers. I would consider taking my current pump out, keeping it as backup, and buying a used Super pump housing (with correct specs) and then adding a Neptune to it but I need to make sure I buy a housing with the correct interior bits.
Thanks for all the help
RJ60 SWG
60cf DE filter
No automation
