Results 1 to 8 of 8
Thread: No suction for vacuum
    I can't seem to get enough suction to vacuum up dirt\sand by my main drain. I tried closing one of the skimmers.. but that didn't help much. The only thing I can think of is to try removing the skimmer baskets. Other ideas?
    2003 Marquis Euphoria - 400gal
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: No suction for vacuum
    Quote Originally Posted by jjdurrant
    Your filter might need backwashing. Just a thought.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Nope.. just backwashed
    Have you tried turning off the main drain?
    I have not
    That did the trick! Thanks.
    My vacuum head sucks though. Which do you guys recommend? Also, should I vacuum to waste or the filter?
    Apr 2009
    Sarasota Florida
    143
    Either, but vacuuming to waste will drop the water level pretty good. Where to filter will not.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    I ended up picking up the sand\silt bag for my Polaris... no need to vaccuum now.
