Well, your options are these -
1. Wait for the FC to come down and try to deal with the cloudiness issue (it's very likely chemical in nature); OR
2. Winterize the pool, cover it and wait until Spring.
If you choose option #2, then I would advise that the pool be uncovered and opened as soon as the water temperature hits 50-55F consistently. That's below the 60F point at which algae likes to start to grow but it's warm enough to start up a pool. The reason I suggest this is because, right now, the pool is a bit of mess chemically speaking and with the high CYA there's a very good chance all that CYA could be converted to ammonia over the winter (by bacteria). If you wait too long in the Spring to open, you'll be fighting both a green swamp AND an ammonia mess both of which will require large amounts of liquid chlorine to fix. IN the meantime, it would be good to know what your daughter was shocking the pool with and then, come next spring, switch exclusively to bleach/liquid chlorine and stay away from the solid chlorine products.
