I agree with Crackerjack4u, I think you got a lot of algae in the pool that got a big jump on you while you were away then insufficient circulation let it get father ahead. In my reading it seems people with cartridge filters have more difficulty because the filter clogs easier, be sure to clean filter when pump pressure increases 20-25%. I had to backwash the sand filter 3 x a day the first 3-4 days then it slowed down and when the water cleared it cleared fast. I also did a lot of vacuum to waste everyday until water cleared and I could actually somewhat see the bottom, then that also cleared real fast. My FC really dropped way faster than yours is even with pump on high, I was adding 2-3 a day gallons of 12.5% for first 3-4 days. So I would say your circulation or filter turn over is somewhat slower than mine but you are probably more cost efficient than I am in the long run. I also kept overshooting my slam # by a few ppm because it dropped so fast and I could not be there enough so I think that is a good idea, however I do not know what is too much and would start to damage equipment. But hang in there I think you are on the right track, I too am very impatient and my impatience bit me a few times.
Also if you want to get better and probably faster filtration you may want to look into slime bag or similar. Swampwoman seems to know a lot about these, although I have never used one. I am still where you were leading a pretty charmed life and not really having problems. Hope it continues (LOL) Best of luck but it is really science we just do not know all the variables. If it doesn't clear in a few days ask for help from chem geek he is great for the tough problems.
