My salt levels are at 4100 in my 10 k fiberglass pool with the Swg on high for a week still not getting any Chlorine to register when I test. I've cleaned the swg with acid and is spotless pool is one season old .
Regardless of how you got to no chlorine, you now have no chlorine and will likely need to SLAM.
Boost the FC with liquid chlorine anytime you see it dipping in the future. Like now. Add 5 or 6 ppm immediately. Overnight Chlorine Loss Test tonight to see if you nees to SLAM Process.
You simply cannot SLAM with test strips and the pool store won't test you as many times as you'll need, if they're even open when you need like the overnight test. See Test Kits Compared if you dont have one already.
