Britali
- Jun 15, 2022
- 193
- Vinyl
- Intex Krystal Clear
Pool math will give you a “recommended” range and an “ideal” range and will put up a notice if you are out of ideal range but still in recommended (on my app it is a blue ! instead of a red !) so do not worry so much if it is out of ideal but still in recommended.how do i figure out the PPM?? this morning after adding chlorine, my FC test shows 3.5 and the yellow on the chlorine test was darker than the colors on the container.. pool math is telling me 3.5 is too high and my ph of 7.5 (best guess as all the colors look the same really) is too low. This really is not simple lol
ps CYA still 0 as i havent got to walmart yet to buy any
The biggest thing about pH is keep it in the 7’s. I monitor my pH and when it goes to 7.8, I add muriatic acid to bring it back down to 7.2 then watch as it rises until it gets to 7.8. I used to wait until 8.0 to bring it down but I ended up with scale on my salt cell so I try to keep my CSI between the -.3 & +.3. End of story do not worry about an exact pH level every day as long as it in the 7’s. When it gets to 7.8 or 8.0 add muriatic acid (amount from pool math) to bring it down to 7.4 or 7.2.
As far as FC, higher is not going to hurt you…it is low that is going to lead to problems. There is big range for higher FC since slam levels do not hurt you & they are much higher than regular levels. The basic gist of it is that you want it high enough for any FC loss during the day to NOT go below your minimum FC. I set my minimum in my mind 2ppm above app minimum and I shoot for maintaining 10% of my CYA. So I consider FC 5ppm my min even though app says min FC 3ppm. And since my CYA 70, I try to maintain FC 7ppm. Maintaining FC though for me is easier since I am using a saltwater system but I do boost with liquid chlorine if my saltwater generator can’t keep up. If I was on liquid chlorine only, I would give myself an ideal target range based of what I lose on a HOT day. Say my FC loss on a hot day is 3ppm and my min FC I set is 5ppm (2ppm above the app min of 3ppm so I should always have a safe cushion)…I would set my ideal FC at 8ppm to account for that 3ppm loss per day and even if I add it in mornings and the sun eats up 3ppm, I am still at my 5ppm min (above the 3ppm absolute min) so never a danger of developing algae.
Hope that helps you to not stress for exact but get comfortable with the range. And that it is more important to stay ABOVE the minimum FC & not even get close because you will not be out there testing every hour of every day…and not sweat the higher FC (as long as not crazy & above SLAM lol which would be expensive to maintain).
