In process of balancing water for pool opening in a few weeks. In testing my CYA, it tested out below 30. I expect it's at or near zero. The water was pretty clear (saw black dot easily) with test water above the 30 mark on the testing tube. I found it strange that my CYA would have droped to 0 from last fall when I was sitting at 40. My CYA is typically pretty stable from fall to spring. We did get a lot of rain, but not unusual weather from years past. The pool surface did freeze this winter (that's a first). Just curious if this drop in CYA sounds strange to the pool experts in this forum. I've already ordered my stablizer... again just curious. Thank You.
Salt water pool. 20,000 gallons, test kit: Taylor K-2006.
