- Nov 12, 2009
- 324
- Plaster
- Pentair Intellichlor IC-40
From the pic, we can see they are still pumping to keep the local water table low. Don't let them dispose of the PVC that the pump is hooked to. If you should ever need to drain the pool and keep the water table low (like for refinishing), you will want to be able to access that piece of PVC again. I suggest they put on an elbow and bring it over to the fence line, then cap it off. Even better would be if you could get them to route it over to the equipment pad and cap it there.
Did they discuss with you wetting the surface to build strength into the walls?
