Check for cracks in the inside of your spa near that areaGetting this white buildup on this tile above the water line. Any ideas how to prevent/clean? Pumice stone works but kind of a pain. View attachment 553928
It is not.The entire pool and spa were replastered and retiled less than a year ago so hoping it is part of the curing process in some way.
You should figure out where it’s leaking from or it’s just gonna come backVery interesting. Spraying with diluted muriatic acid did the trick.
Water getting behind tile is a leak. The age of the plaster/tile doesn’t matter so much. Cracks and leaks can happen to even when new.It is the tile around the waterfall edge that spills over from the raised hot tub into the pool. Again, the plaster in the hot tub and pool is less than a year old so I'm guessing it is just water getting behind the tile around the waterfall. Or it could be the coping joint in the hot tub that faces that direction. I'll take a closer look now that I have a clue.
But spraying a little diluted acid on it every now and then isn't the worst thing in the world given all of the other upkeep required!
Yes it works. However it is moisture behind there it will come back after a bit. It's very very common. Re tile on pools is very tricky. I have a feeling you have water back behind there from either the job itself or a crack somewhere.Very interesting. Spraying with diluted muriatic acid did the trick.
