- Nov 13, 2023
- 90
- Vinyl
- CircuPool Core-55
Now that I’ve got my SWG up and running in my 17k gallon indoor inground pool with an automated cover, I want to tackle some deep cleaning and need recommendations.
The pool is 14 years old, I purchased the house last fall and had many issues with less than optimal care from the previous owner and pool company.
My water is balanced now and crystal clear.
I have some corrosion issues on the edge of the coping. I’ll include pictures. There’s white crusty/chalky build-up as well as a lot of blue shock granules with copper that the previous owner was using regularly.
The coping looks like painted metal I believe.
This is by the corner stairs. You can see all the build up in the pool cover recess and along the edge of the coping/paint.
The amount of buildup on the coping is less on some areas like above.
Suggestions on what I can use to clean this (Simple Green, Dawn dish soap, etc.) and what to use (a scrub brush or what)?
Also on the end of pool where the pool cover sits when it’s retracted (fully open) has a lot of crud and brown water that my sits in this recess. I want to get rid of all of this. What should I clean this with?
There even some areas like above where it’s eaten it’s way through this metal base that the cover sits on. And has lots of white/brown buildup.
Thoughts on how best to clean all of this?
And what’s the best to use to scrub/clean the vinyl liner while I have the pool full? The liner is 14 years old, but no leaks so I don’t need to replace it now but I want to try to get it as nice looking as I can.
Thanks!
Thanks!
