First water test
Hello
I just tested the water (with HTH test) and the result es
PH 7,5
Cl 4
I dont have to add anything today right? Or I must target 5 with 2,4 oz?
1 for target makes difference?
It's up to you. If you only lose 1 overnight, then tomorrow you'd be at three, which is your minimum. Or would you be at 3? How accurate is that test kit? Hmmmm...
No swiming yet.
I used the básic oto.
The FAS-DPD is more accurate?
The TA was 110 and the CH 40
Yes, the FAS-DPD is waaaaay more accurate. I'll almost guarantee that if you run the two tests using the same sample water, they'll disagree by at least 1. I can never tell the difference anywhere between 4 and 7 on the OTO, but the FAS-DPD never fails.
