Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Solid wood cover for winter
    Western Pennsylvania
    151
    I was thinking, after too many winters with all the leaves, water, snow and ice on my cover, that this year i would build a plywood cover and put my winter cover on top of that to keep the wood dry.
    Any one else ever done this?
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    South Central NJ
    3,192
    Re: Solid wood cover for winter
    One word: WEIGHT
    Scott
    Owner of - PoolGuyNJ LLC
    Jan 2010
    Randleman,NC
    620
    Yes,Weight.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    My neighbor built a set of trusses for his pool and puts his blanket over them. They slope downward on one side allowing rain and melting snow/ice to just run off.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    South Central NJ
    3,192
    There is a BIG difference in Ky's snow loads and Western Pa's.
    Scott
    151
    Weight was my thought. it was simply going to be some plywood laying flat on the top of the pool, my other design I had thought about was attaching one end to the deck and the other side sitting on some 4x4 posts so that it would be a few inches above the pool and have the cover under that
    Sand filter
    Jandy gas heater
    Intermatic timer
    Without trusses (beams spanning the pool) it will never hold. Plywood alone is way too flexible. By the time you build something that will be strong enough it will be a major project. It would be simpler to just use a normal cover.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    What about a 16' round trampoline? Kind of like a mesh cover with a built-in frame.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Jan 2010
    Randleman,NC
    620
    Heavy still....Metal Frame...If it was that simple someone would have made million's.just saying..Just the cover with snow,ice,etc is bad enough.You wonder why they don't last..That's why I have just started buying the cheapest cover .Then I just throw away..Plus,the mesh cover will let light in& you don't want that..Dark= nothing growing.lol
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by kplaster
    Well, I'm a fan of my Loop Loc mesh cover, so letting light in doesn't bother me.
    Anyway, just a thought!
    TF-100 test kit.
    Apr 2012
    Bonner Springs, Kansas
    109
    Quote Originally Posted by CUTiger78
    Agreed, been through 2 seasons with a loop loc mesh cover and no issues so the light hasn't been a bother. The mesh for me has worked well.
    For the wood cover, I guess I'm confused at the reason to go with that solid of a solution. Seems the money you would pay and the time investment wouldn't pay back on chemical savings with a pretty big risk of cost if it collapsed.
    Also, Where would you store this thing when not in use?
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by radefeld
    I was referring to the trampoline..loop-loc mesh cover's are not the same as the trampoline cover..Loop-loc mesh doesnot let sunlight through.Trampoline material does..
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I've been swimming under my loop-loc cover and it sure looked like it was letting sunlight through, but whatever....
    TF-100 test kit.
    Jan 2010
    Randleman,NC
    620
    Yes, if you would check info on loop-loc.It block's 100% of sunlight..I don't think I would be swimming under it.Each is on..
    151
    My only reason for thinking about this is that i have 67 trees in my 1/2 back yard so leaves and rain during fall means i have a cover with a foot of water and leaves on it so i then have a big clean up job before winter comes and then in winter i have the same issue with rain and snow.
    No matter what i do my cover never seems to stay tight fitting it always sinks down until its sitting on the water in the pool, i have put weights all around it but that didnt help.
    Sand filter
    Jandy gas heater
    Intermatic timer
    Jan 2010
    Randleman,NC
    620
    Don't think there is much hope.Except,cleaning off during the fall&winter..I believe I would take the blower to it when getting up the leaves through the fall.That's why I don't have tree's.UGG !!!hate the leave's.
    South Central NJ
    3,192
    1) Loop-Loc's Mesh-II cover will let light in. This is the only mesh material for a cover they have. Some other brands have a mesh that will stop light but they weigh a lot more.
    2) Loop-Loc's On-Ground covers are stretched tight to the special anchors set around the perimeter of the pool. If there is a deck around the pool, deck anchors are used if 5/4" wood was used. Engineered products cannot be used as they tend to be too soft a material and the anchors will come loose.
    3) Tarp style covers are supposed to sit on the water's surface. They are supposed to form a barrier between the pool's water and the elements. If a tree branch pokes a hole in it, the barrier is broken and pool water can get out and weather can get in. There is isn't anything you can do.
    Scott
    Jun 2012
    MA
    347
    You could put a canopy over the pool in the fall. That would keep most of the leaves and rain out. Might have to take it down before it starts snowing.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    The original Loop-Loc mesh cover let light in.
    I have the Loop-Loc II cover, and like mentioned before, it lets in very little if any sunlight.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
  20. Back To Top    #20
    Loop-Loc does advertise that their Ultra-Loc II covers block 100% of sunlight. However that is not literally true. They do block better than 99% of sunlight, which is about the same thing as 100% as far as algae is concerned, but they still let in enough light that you can see. People can see at extremely low levels of illumination, a tiny fraction of 1% is more than enough.
