Thread: New SPA setup
    May 2013
    Chandler Arizona
    78
    New SPA setup
    Is there a chemicla calculater for a spa, or can I use the same Pool calculator?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: New SPA setup
    You use the same PoolMath, but due to rounding you might put in 10 times your spa volume and then use 1/10th the amount of chemicals it says to use. For example, increasing FC by 3 ppm in 350 gallons would say 0.3 ounces weight (0.2 ounces volume) of Dichlor, but if you used 3500 gallons it would say 2.5 ounces weight (2.4 ounces volume) so that you can see the real numbers for 350 gallons are 0.25 ounces weight (0.24 ounces volume).
    You then need to multiply ounces volume by 6 to get teaspoons so 0.24*6 = 1.44 teaspoons so roughly 1-1/2 teasoons.
