I have a large pool and have been following TFP methods for years. Test my water almost everyday.
I just purchased an Aquaterra Viceroy acrylic spa from Costco and have it in place. Waiting for electrician to come wire up before filling.
I looked through the Pool School book and the sticky threads. Is there a separate document or Spa 101 thread I can reference to get started? I believe the spa I purchased comes with an ozonator, realize some don’t like those but this so has one all the same.
The spa owners manual mentions using PH down & PH up, sodium bisulfate & sodium hydrogen carbonate. All I use for my pool is liquid chlorine and muriatic acid. I have a bunch of baking soda but have never needed to use as I am always fighting my TA & PH to get down in the pool
For sanitation the manual suggests sodium dichlor. I would assume you only use a little of this to get cya up to a certain level and then use liquid chlorine.
The manual also mentioned MPS for shock, which I’ve never used.
Sorry for the long post. If there is a spa 101 thread or ebook I’m happy to read study & follow.
Will most likely fill with my softened water, as my well water is very hard.
Thank you for any assistance!
