- Nov 30, 2019
- 853
- Fiberglass
- Hayward Aqua Rite (T-15)
I haven’t been able to use my (Hayward) Skim Vac skimmer plate with my Zodiac G3 vac. The plate sits high in the skimmer on the basket and I have not been able to cobble together the 45 or 90 degree elbows required to get it turned horizontal and out the skimmer opening and still remain reliably below the water line. The big issue is incorporating the supplied ‘FlowKeeper Valve’ in the mix. It has to stay below the water line because it opens to control suction by design and will suck in air and the pump will lose prime if it’s at all above the water line.
I can use the G3 and FlowKeeper without the Skim Vac plate, there’s plenty of room in the skimmer to insert the FlowKeeper valve vertically, directly to the skimmer suction opening, but of course then there is no skimmer basket, and skimmer sock, to catch vacuumed debris. I’m then depending on the pump basket to catch debris before it gets to the filter. That will catch the bigger stuff but not the same as a sock.
Note: I have another skimmer plate with a built-in/keyed 90 degree elbow but it does not extend up high enough to even exit the skimmer.
A couple of questions:
Has anyone used a skimmer sock on the pump basket? Any issues with that?
Any ideas on how to solve the problem and incorporate the Skim Vac plate with the Zodiac G3 and FlowKeeper valve?
