I have a Tagelus TA60 sand filter with Pentair multiport valve. I'm using Zeolite instead of sand.
I recently drained my pool, had it sandblasted and then applied new epoxy. After restart I started getting Zeolite (I think) in the pool.
I did a deep clean of the Zeolite, per instructions on TFP, in case it had become channelized. I replaced the spider gasket assembly. No change. With the pump turned off there is no accumulation/leakage, so it's not insect droppings from the overhanging trees.
What's weird is that the Zeolite leaks into the pool even with the multiport valve set to Recirculate. In case the Zeolite had somehow built up in the piping somewhere I ran the pump on high/Recirculate for an hour, but again no change.
While writing this post I did notice the word "sand" in sandblast. I cleaned the main drain sump really well after the sandblasting. It's not impossible, but I doubt what I'm seeing is related to the sandblasting. I do think it is Zeolite that is leaking.
My next step is to remove the Zeolite and inspect/replace the laterals, but I want to check in with the collective wisdom to see if the Zeolite leaking even on Recirculate might indicate some other problem.
Thanks.
Thanks.
