So I'm looking to upgrade from an old 1 hp single-speed Sta-Rite to a VSP and would like some help on sizing / the model to buy. Some hopefully useful background:
Pool Size: about 16k gallons? It's hard to calculate because it's a kidney shaped pool that gradually goes from about 3 feet to 9 feet plus has a small attached spa (at least that's easy to calculate)
Filter: cartridge style, 136 gpm max (I think)
Current Pump: Sta-Rite 1 hp 230v
Current Run Time: about 4-6 hours per day
Additional Equipment:
large Hayward HeatPro electric heater (it's bigger than my home AC unit)
small spa with 4 jets (no booster pump)
suction side cleaner
Ingress / Egress:
1 skimmer, 1 main drain, 1 spa drain, 1 cleaner suction
3 pool returns, 4 spa returns
Piping:
1.5" everywhere
pump is maybe 20' from the main drain and cleaner port, and 35' from the skimmer
pump is about 1-2 feet above the skimmer
doesn't seem to have too many bends except when you get close to the pump itself
4 T junctions suction-side to combine all the inlets
1 T junction return-side to switch between pool & spa
Automation: none currently, though I'm interested for the future. Having 1-touch "spa on / spa off" would be great for my wife.
I was thinking about either the Hayward SP2303VSP MaxFlo 1.65 HP for $680 or Hayward SP3202VSP 1.85 HP for $1090. It seems difficult to justify getting something around 2.5+ HP for $1500+ when things worked pretty well with our old 1 hp pump, though I would like a little more power in the spa jets. I'm not against the Pentair Intelliflows, but from my limited research it seemed like Hayward was the better value and more efficient energy-wise. That would also match brands with my heater which could be useful for future automation?
Ingress / Egress:
Piping:
1.5" everywhere
